1991 camry Brake problems
1991 TOYOTA CAMRY
OLUBODE08
hi i got a 1991 camry mileage like 150,000..its a stick shift ..but i was driving it for sumtime and i kno i needed the brakes pads change..but one day while i was driving it and i pressed the brake the brake just made a big thump sound..and now when i press it the brakes thiers no pressure as if im not pressiong anything..i know i need the brake pad change..so can sombody give me an estimate and tell me if thats all i need to do ...
Jun 27, 2007 at 10:22 AM
AACPLUS
  • 60 POSTS
first, look for fluid leaking. If a caliper failed, you have no pressure. If a cylinder failed, you may have little or no pressure. If you have no leakage, try this.
make sure the M/C reservoir is full. crack the lines coming off the M/C one at a time and apply brakes. you should have a solid stream of fluid expel. if no pressure or just a dribble of fluid, you have a M/C problem. If you have good pressure there, bleed the cylinders/calipers. if there is no pressure at wheels, you have air in lines or contamination most likely. you may also pinch the hoses to block flow to cyls/calipers, and see of the pressure holds. if the pads are too low, you can over extend or even blow a caliper piston from it's housing. Sometimes, a brake pad may even fall out and cause the caliper to over extend or fail. if the caliper is at fault, suggest replacing in pairs.
Hope this may help.
Jun 27, 2007 at 10:49 AM
