1990 Toyota Camry wont go on 4 cylinders when cold
1990 TOYOTA CAMRY
300,000 MILES • 4 CYL • FWD • AUTOMATIC
GIZMO302
Ive got a 1990 4 cylinder camry (carby) that will not go on 4 cylinders when it is cold
It has good compression on all cylinders,new leads etc
ive put new plugs in
ive ruled out a vacum leak, or carby problems.
it does not go on number one cylinder until it has warmed up for about 5 minutes then it runs real good
anyone got any ideas?
May 31, 2008 at 11:31 PM
KHLOW2008
  • 41,814 POSTS
Hi gizmo302,
How sure are you that it is not due to vacumn leakage?
Is there any oil in the distributor?
Jun 2, 2008 at 6:26 AM
