1990 Toyota Camry Using lots of oil
SASHTROUBLE
  • 1990 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 270,000 MILES
My car uses a lot of oil, but it runs fine. I commute for work and am driving about 700 km's a week. What o you think the problem could be?
Saturday, December 6th, 2008 AT 2:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The oil is probably being pushed into the combustion chamber and being burnt away. If it is a small leak, then you will see no smoke signs. Could be caused by cracked head gasket, valve guides, piston rings.
Saturday, December 6th, 2008 AT 2:21 AM
