1990 Toyota Camry tail lights dont turn on
226,897 MILES • 4 CYL • FWD • AUTOMATIC
KEITH01
I just need to know where. The fuse is to see if that's the problem I don't have the cover to the fuse box and I don't think a fuse is blown in the box under the dash.
Sep 26, 2010 at 6:02 AM
PITCREW94
  • 18 POSTS
Did you check your break lamp fail relay? This is pretty common on this year camry. It can also be the break lite switch under the break paddle
Sep 27, 2010 at 5:52 AM
