THANK YOU FOR YOUR TIME. MY QUESTION IS THIS, I HAVE NOT HAD MY 1990 FOR MORE THAN 2 MONTHS SO I AM GETTING AQUANTED WITH IT. THIS QUESTION CONCERNS THE OVERDRIVE. ON THE SHIFT THERE IS A SMALL RAISED BUTTON AND THAT TURNS ON AND OFF THE OVERDRIVE. OFF/OVERDRIVE SHOWS UP IN THE DASH WINDOW LOWER RIGHT CORNER. I NEED TO KNOW IF I AM TO USE THE OVERDRIVE, EVEN IF I AM NOT PULLING ANYTHING. IF I USE IT, DOES IT BEING ON SHOW IN THE WINDOW AS BLANK OR OFF/OVERDRIVE? THANK YOU FOR YOUR TIME.
Jun 23, 2008 at 4:24 AM
