1990 Toyota Camry oil in radiator
1990 TOYOTA CAMRY
RUSTY.LALMAN
Engine Cooling problem
1990 Toyota Camry 4 cyl Front Wheel Drive Automatic 230k miles
I have noticed oil in my coolant but no water in the oil. There is a oil leak that falls on the thermostat housing. Is this the housing gasket or head gasket?
Sep 26, 2010 at 9:34 AM
Have it block and pressure tested to rule out the headgasket, cracked head or block and an intake leak
Sep 26, 2010 at 9:54 AM
