1990 Toyota Camry motor mount and crankcase pully
MAXX12
Engine Mechanical problem
1990 Toyota Camry 4 cyl Two Wheel Drive 90,000 miles
I am trying to get to my timing belt for replacement and
everything was going smooth until I ran into getting the
bolt off the crankshaft pully, I do not have a impact
tool and the crank keeps spinning also I have taken all the nuts and bolt off the motor mount which is in the way of the timing belt and can not figure how to get it
out of the way. any suggestions please Maxx
Jul 17, 2008 at 6:54 AM
DOCFIXIT
  • 18,828 POSTS
Rent an electric impact
With all the bolts out mount need to raise engine. Put a floor jack with small block of wood under oil pan raise up remove mount.
Jul 17, 2008 at 7:18 AM
