1990 Toyota Camry MISSES WHEN WET
RICHDONATT
  • 1990 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 140,000 MILES
ENGINE MISSES/BUCKS WHEN RAINING I CHANGED THE DISTRIBUTER CAP AND PLUG WIRES STILL DOES IT. WHAT COULD THE NEXT MOST PROBABLE CAUSE? IT SEEMS TO RUN OK WHEN NOT RAINING BUT IT DOES SEEM TO HAVE A SMELL OF GASOLINE AFTER FILLING THE TANK AND IT HAS PRESSURE IN THE SYSTEM THE SMELL GOES AWAY WHEN I OPEN THE FUEL CAP AND RELEASE THE PRESSURE COULD THIS BE RELATED TO THE RAIN PROBLEM?
Monday, March 29th, 2010 AT 10:35 AM
CARADIODOC
  • 33,910 POSTS
Use a spray bottle to mist the ignition system. That will mimic driving in the rain.
Fill the spray bottle with water and a little dish soap, then spray the charcoal canister, vacuum hoses between it and the engine, and back to the fuel tank when the system builds pressure to see if there is a leak.
Caradiodoc
Monday, March 29th, 2010 AT 12:47 PM
