1990 Toyota Camry car is 4 cylinder but runs in 3 cyl
BIKASHDHUNGANA
MEMBER
1990 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
260,000 MILES
I bought a car six months ago. One its not strt. I take car in service station. They rmoved imobliser and say its run on 3 cyl. They suspect dizzy cap and leads coil.
now its run in 3 cyl but car doesnt run well and vibarating. Is this possible? How much cost for repair?
please tell me
SPONSORED LINKS
Saturday, February 28th, 2009 AT 9:46 AM
GRSMNKY
MEMBER
A first step when buying a car with high mileage is to do a tune up. Replacing spark plugs and ignition wires would be the first step. Or if on a budget you can check which cylinder is not working and try to fix a possible loose wire or clean dirty spark plug. I wouldn't drive on 3 cylinders though, it shoots unburned gas into the exhaust which is not good for the exhaust or you since it can explode.
