1990 Toyota Camry mass airflow sensor
SHAMTASTIC
Engine Mechanical problem
1990 Toyota Camry 4 cyl Front Wheel Drive Automatic
I was replacing the distributor cap, and removed the mass airflow sensor and hoses so Icould get to the srews on the cap. Well, I broke some of the connectors coming from the cable that plugs into the mass airflow sensor, and inside the sensor. The engine turns over, but after a couple seconds just dies. Is there a way I can bypass the sensor to drive the vehicle to the shop, or should I just order the part and install itmyself?
May 24, 2008 at 5:32 AM
LEGITIMATE007
  • 5,121 POSTS
your better off ordering it from us and installing it your self. you dont' want to monkey rig it and then short something out in the computer then your really f'd. just click on the the first link on the bottom of this page and click on discount autoparts. you'll see these prices are pretty damn good compared to others
May 24, 2008 at 7:05 AM
