Hi 2 car pros:
Thank you for taking my question. I had the timing belt replaced at 148,000 and timing checked ok at 10 degree BTDC.
Now when I time the engine by rotating the distributor I cannot line up the timing mark to the proper specs. The timing mark is below the number indicator despite rotating the distributor to the maximum position.
Can you please help.
Thank you in advance.
Sincerely,
Stan
Sincerely,
Stan
Mar 20, 2009 at 5:16 PM
