1990 Toyota Camry HEATER
JONSMITH
Heater problem
1990 Toyota Camry Front Wheel Drive Automatic 85,000 miles
I have heat to the heater core,,But inside car with fan on its only warm..Like the fan is not blowing across heater core!
Jan 14, 2008 at 1:30 PM
  • 75,988 POSTS
Lets check the coolant level-replenish it and go find the thermostat and replace it and see what happens-stiil not enough heat-comeback and we'll get that heat going-so you get warm and cozy.
Jan 14, 2008 at 7:02 PM
JONSMITH
I have replaced coolant,thermostat. Hose in and out of heater core gets hot but not much heat inside car..Seems like fan is pullin in no heat from across the core..
Jan 15, 2008 at 9:29 AM
  • 75,988 POSTS
Time to tear it apart and investigate- air mix/blend door actuators/vacuum hoses.
Jan 15, 2008 at 9:34 AM
