Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Brakes
Parking Brake
Adjust
1990 Toyota Camry hand brake adjustment
1990 TOYOTA CAMRY
145,000 MILES • 4 CYL • 2WD • MANUAL
GLENN STORIE
MEMBER
1 POST
How do you adjust the hand brake on a 1990 Toyota Camry?
Jan 25, 2008 at 8:33 AM
Experienced Mechanic
Remove the center console-to gain access to the cable adjuster.
Loosen the upper locknut-while holding lower locknut-then tighten the adjusting nut until desired travel is obtained-then tighten locknut.
Mar 11, 2021 at 4:49 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
