1990 Toyota Camry hand brake adjustment
145,000 MILES • 4 CYL • 2WD • MANUAL
GLENN STORIE
How do you adjust the hand brake on a 1990 Toyota Camry?
Jan 25, 2008 at 8:33 AM
  • 75,988 POSTS
Remove the center console-to gain access to the cable adjuster.
Loosen the upper locknut-while holding lower locknut-then tighten the adjusting nut until desired travel is obtained-then tighten locknut.
Mar 11, 2021 at 4:49 AM
