1990 Toyota Camry Electrical rear running light
200,000 MILES • 6 CYL • FWD • AUTOMATIC
PENN247
my tail lights won't turn on when i turn my running
lights on. And i checked the fuses and the lightbulbs
and there are working fine. Do you any other
suggestions as to other posibilities it could be.
May 24, 2009 at 4:30 PM
KHLOW2008
  • 41,812 POSTS
Hi penn247,
If the front lights are working, then it is not a fuse or switch problem. At rear on left quarter panel there is a light failure sensor, check if it is working.
Jun 1, 2009 at 8:11 AM
