1990 Toyota Camry Broken Tie rod inner
BCTREEFROGS
  • 1990 TOYOTA CAMRY
Tires and Wheels problem
1990 Toyota Camry 6 cyl Two Wheel Drive Automatic
I have a broken tie rod, I'm about 90% sure its the inner one, all I need to know is how hard it is to fix and what kind of tools I will need. Thanks in advance.
Thursday, October 15th, 2009 AT 6:00 PM
JOE C.
  • 25 POSTS
What makes you think its the inner tie rod?
What are the symptons?
I could be wrong, consult a Haynes manual, but on this model I think its easiest to pull out the rack, then replace the inner. If you decide to do it while the rack is still installed, then you will need a special tool. Do an internet search to find an inner tie rod removal tool with the correct size adaptor.
Friday, October 23rd, 2009 AT 5:58 AM
