1990 Toyota Camry Brake lights work, tail lights don't
1990 TOYOTA CAMRY
KBBOY
Electrical problem
1990 Toyota Camry 4 cyl Front Wheel Drive Manual
I just replaced the tail lights. The brake lights work the tail lights don't but I think they are the same bulb. Any suggestions why that would be happening.
Thanks,
Rex
Aug 11, 2008 at 5:28 AM
KHLOW2008
  • 41,814 POSTS
Hi kbboy,
Brake and tail lights works on 2 different circuits, if the bulb is correct, you need to check the taillight relays or fuses.
Are the dash meter backlights and fron DRL working?
Aug 16, 2008 at 9:56 PM
