HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Tires
Replace/Remove
1990 Toyota Camry bearings
CUZ-E-CAN
MEMBER
1990 TOYOTA CAMRY
Tires and Wheels problem
1990 Toyota Camry Manual 159000 miles
What all is involved in replacing the bearings. Is it a user replaceable part. I've worked on lots of cars except for a camry.
Wednesday, October 29th, 2008 AT 5:57 PM
MECHANIC
Hi there,
Hi there,
If you are talking about the engine crank shaft bearings, this is a an engine out and full strip down, and crankshaft removal, this is a major job.
Mark (mhpautos)
Wednesday, October 29th, 2008 AT 6:47 PM
Please
login
or
register
to post a reply.
Related Tire Replace/Remove Content
1997 Toyota Camry Should Tires Be Changed??
I Have A 11 Year Old Camry With Little Use And Mint Condition As Original Owner. The Tires Are Oem With Little Wear And Concerns Me About...
Asked by
camman 2
1 ANSWER
1997
TOYOTA CAMRY
GUIDE
Wheel Removal and Tighten
There are typically two types of wheel covers which can hinder the removal of the lug nuts and wheel. The first is the complete hubcap which needs to be removed to gain...
2000 Toyota Camry Removing
Tires 4 Lug Removed And Tire Still Wont Come Off
Asked by
kylefortin
1 ANSWER
2000
TOYOTA CAMRY
Alignment
My 2009 Toyota Camry Has Had 3 Alignments Since Bought New. The Tires Have 22,000 Miles On Them And I Have Been Informed That They Are All "...
Asked by
tswartzla
2009
TOYOTA CAMRY
Car Sways In Curve
Car Sways In Curve Not All The Time Feels Just Like You Hit A Patch Of Ice And It Slid For I Split Second Feels Like You Have No Controle...
Asked by
pecc38n
1997
TOYOTA CAMRY
Driving Noise
While Driving Any Speed There Is A Loud Noise That Sounds Like Having Snow Tires On, I Have Changed Tires Twice. The Noise Is Getting...
Asked by
lwkester
1 ANSWER
TOYOTA CAMRY
VIEW MORE
Safely Change Your Spare Tire
Control Arm Bushing Replacement - Lower
How to Check Tire Air Pressure?
