1990 Toyota Camry accleration
WRICE24
  • 1990 TOYOTA CAMRY
Shakes or Wobbles problem
1990 Toyota Camry 4 cyl Two Wheel Drive Automatic
hey I have this car but it wont start sometimes and it has a new started on it, new fuel filter, and every time I press down pedal to floor it seems to not want to go?
Saturday, September 18th, 2010 AT 5:27 PM
Next time it refuses to start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, September 19th, 2010 AT 4:01 AM
