1990 Camry D 4 Cylinder 2.0 113K Miles: ECU Question
DONOVANK
Ok so after two months of issues, my mechanic was able to determine that my drivablity issues were the result of a failing Mass Airflow sensor and Throttle Position Sensor. When he replaced those, the car drives fine, but I still have the hard start issues after having sat for longer than 3 hours. I put the key in, turn, ,she starts...then dies. Usually she will start on the second try. He then realized that something wasn't triggering the fuel pump to prime...so he changed out the Main Relay...and nothing...so we have determined that they ECU is going bad and more than likely needs to be replaced. Something that costs money...money I'm going to have to save...my question is...if they starting thing is the only issue that I'm having in regards tot he ECU...and she drives like a top...do I need to be in a huge honkin' hurry to replace the ECU...or can I take my time and save up the funds...or could it not be the ECU and we could be missing something...
Oct 9, 2007 at 3:50 PM
  • 75,988 POSTS
Lets try this 1st have the fuel pressure check and comeback with the readings.
When was it last major tuned-up?
Oct 9, 2007 at 10:45 PM
DONOVANK
[quote:6917a8aa51="rasmataz"]Lets try this 1st have the fuel pressure check and comeback with the readings.
When was it last major tuned-up?[/quote:6917a8aa51]
The last two times he checked fuel pressure they were within the normal range. He did put the pump in diagnostic mode and the car started up just fine.
I do need a major tune up. I have had the car 9 months and have been doing basic maintence. Do you suggest a tune up before I consider replacing the ECU?
Oct 10, 2007 at 1:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:834f0ee094="DonovanK"][quote:834f0ee094="rasmataz"]Lets try this 1st have the fuel pressure check and comeback with the readings.
When was it last major tuned-up?[/quote:834f0ee094]
I do need a major tune up. I have had the car 9 months and have been doing basic maintence. Do you suggest a tune up before I consider replacing the ECU?[/quote:834f0ee094]
the ecu isnt the prob, cold star injector needs checked, and check the tune up stuff, check the coil for burn marks in the distributor if present wires need replacing too with a coil
Oct 10, 2007 at 7:12 AM
