My light out warning light keeps coming on?
158,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEFTHANDER12324
My warning light keeps coming on .to warn me theres a light out .But theres no lights out . I notice it only comes on when i step on brake pedel. restart the motor it goes out ,comes back on hit brake pedel. Some times it go off for a few weeks then come back on ...
Oct 30, 2008 at 3:52 PM
More than likely you have an issue with the light failure sensor.
I am attaching the wiring diagram below that will help with this, but we need to check the voltage on each of the wiring coming out of it.
Basically, on pin 3 you should have no voltage and if you do then more than likely the resistor inside the unit has failed and it needs to be replaced.
Please run through this and let us know what questions you have and what you find.
Thanks
Nov 13, 2021 at 1:12 AM
  • 110,248 POSTS
I just went through two manuals and neither shows the location. So, from memory, if you open the trunk, it should be behind the left side insulator. It will be a yellow box approx. 3"x3".
I attached a pic below of what you are looking for. Let me know if this helps.
See pic below.
Jul 10, 2022 at 1:42 PM
