1989 Toyota Camry Starter?
1989 TOYOTA CAMRY
RLESINK
Engine Mechanical problem
1989 Toyota Camry 6 cyl Automatic 110000 miles
When I start my car sometimes it makes a hi-pitched screech. This might happen once or twice before it actually starts.
I had an 88 Camry which developed this same issue. Replaced the start about 3 different times and it never fixed it. Is there another issue which could be causing this?
I think I read somewhere It might be the flywheel? If this is the case, how much does it cost to replace the flywheel / whatever part may be bad.
Jul 31, 2008 at 7:38 AM
  • 31,937 POSTS
Hi there,
It may be that the drive plate is damaged & the starter drive is slipping, the transmission has to be removed to do this, i will post an estimate when i can get access to the data base later today (my time)
Mark (mhpautos)
Jul 31, 2008 at 10:58 AM
