Interior problem
1989 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do you remove the inside door handle assembly from the door panel on the drivers side.
I am trying to remove the door panel to replace either the power window regulator or motor and the inside door handle assembly is the hang-up.
updated 1/14/10
Thanks for your quick reply. Honestly, I figured out how to remove the handle yesterday and was able to remove the door panel.
My problem now is to how to remove the power window motor, because it's behind and bolted on to the inside door frame. The bolts I can remove from the outside but there are other screws that needs to be removed which are inaccesible from the outside. Can you help?
Thanks in advance.
updated 1/14/10
Thanks in advance.
Jan 9, 2010 at 5:57 PM
