1989 Toyota Camry fuses for dash gages
1989 TOYOTA CAMRY
135,000 MILES • 4 CYL • FWD • AUTOMATIC
LEFTHANDER1234
  • 5 POSTS
My car keeps blowing the fuse for the dash gages.This fuse allso makes the heater fan,back defroster,and windows work. Its a 7.5 fuse ,i uped it to a ten and till blows ..Hope someone can tell me why it blowing this fuse .Must be some king of over load i guess....
Jan 18, 2009 at 9:13 AM
2CARPRO JACK
  • 11,533 POSTS
Since you know which things are powered by that fuse, try unplugging things one at a time until the fuse doesnt blow, this will tell you which circuit is the problem
Jan 28, 2009 at 6:56 AM
RIDDHIB
I am having exactly the same problem. The guage fuse burns as soon as i start my car and the power window, meter guage, heater, fuel meter don't work. Did you found the solution for this. Let me know
Jan 29, 2009 at 5:52 AM
LEFTHANDER1234
  • 5 POSTS
I keep putting in the fuse 5 or 6 times .Afer that it started working again,but the trouble light came on again.looked and had to replace the control box in trunk for the tail lights.Every thing works now but no back up lights
Feb 4, 2009 at 5:53 AM
SBROWN2144
We have the same window, fan, blower and seat belt problems. My husband has checked every fuse he can find. He even replaced the ones that he understood were the key fuses. It still is not working. What are we doing wrong?
Jul 12, 2009 at 1:13 PM
LEFTHANDER1234
  • 5 POSTS
I had to replace the wires in trunk .cut and repair the wires were the left hinge for trunks is .over the years these wires had become broken .they make the car do all kinds of things fan motor ,brake lights and dash gages ..just cut and peel back the insulation and look .
Aug 21, 2009 at 9:50 PM
