1989 Toyota Camry Filter
SLOPEZ80
Transmission problem
1989 Toyota Camry 6 cyl Two Wheel Drive Automatic
I have a 89 toyota camry wagon and it never had any trouble. It quit running suddenly. It will go 20mph at 4000RPM and the speedometer does not move. I put transmission fluid in car. I need to know if changing the filter will help?
Jun 18, 2010 at 6:33 AM
  • 75,988 POSTS
You need to check if its clogged-up, also could bethe catalytic converter, TPS and VSS and the airflow meter
Jun 18, 2010 at 9:01 AM
