1989 Toyota Camry brake lights
1989 TOYOTA CAMRY
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARJOURIEPAIZ
My brake lights won't turn on when i step on the brake pedal. I have already check the fuses, wiring , bulbs, brake light switch has been change and its getting 12 volts.
Oct 28, 2008 at 4:47 PM
Hi marjouriepaiz and welcome to 2carpros
If the barke switch is properly adjusted and brake lights won't light up-you have an open wire between the switch and rear bulb sockets or lost the ground
Oct 28, 2008 at 5:54 PM
