1989 Toyota Camry 89 toyota camry 4cyl 2.0 automatic
1989 TOYOTA CAMRY
168,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHAELK1973
I managed to figure out how to get the codes off the computer. My question? these are the 3 codes I'm getting 14,24,and 31 what do these codes tell you? I am going to keep looking other places to find codes but the internet is very big.
Apr 3, 2009 at 9:23 AM
Diagnostic Trouble Codes - 1989
Toyota
11 ECU Power Supply.
12 Engine RPM Signal.
13 Engine RPM Signal.
14 Ignition Signal.
21 Oxygen Sensor (OS) Signal.
22 Water Temperature Sensor (THW) Signal.
24 Intake Air Temperature Sensor (THA) Signal.
25 Air/Fuel ratio lean.
26 Air/Fuel ratio rich.
27 Sub-oxygen sensor signal.
31 Air Flow Meter Signal.
32 Air Flow Meter Signal.
41 Throttle Position Sensor (TPS).
42 Vehicle Speed Sensor (VSS) Signal.
43 Starter Circuit Signal.
51 Switch Condition Signal.
71 EGR system malfunction
Apr 3, 2009 at 10:23 AM
