1989 Toyota Camry
234,654 MILES • 4 CYL • FWD • AUTOMATIC
NEVERMORE MIKE
I have oil on two of my spark plugs when i changed
them is this a serious problem?
what do i need to do to fix it?
thank you
Aug 29, 2010 at 7:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely cause is the seals on the valve cover gasket. you will need a valve cover set and plug wires
Aug 29, 2010 at 11:42 AM
