1989 Toyota Camry
KIKI33
Brakes problem
1989 Toyota Camry Manual
How do i adjust my Parking Brake?
Jun 11, 2010 at 7:53 AM
  • 31,937 POSTS
On the side of the brake handle, pull back the black rubber boot, you will see the adjuster pointing up, there is 2 nuts, both 10mm one is a lock nut the other when wound in will adjust the cable, a deep 10 mm socket is best suited to do this.
Mark (mhpautos)
Jun 11, 2010 at 5:13 PM
