i have a short draw somewheres ...i checked the fuses ..ok when i disconnent the main alternator leads from the harness it gose away...i put a new alterntor on and drain remains...pulling 14 volts....i had a simualr problem once with and olsmobile and it turn out to be the wire that gose from the alternator to the ecm on the charge side was bad and a by pass wire was put in ..there are three wires a thick white one ..ok...and a doubled up green and yellow one ....do you know which one is the ecm charge reture..and which port on the ecm to use...or am i wrong completely...
Sep 13, 2010 at 3:20 AM
