1989 Toyota Camry
1989 TOYOTA CAMRY
MARIE O'DELL
1989 Toyota Camry
How do I remove the gas tank?
Nov 28, 2008 at 1:46 AM
  • 31,937 POSTS
Hi there,
Disconnect battery, from under the rear seat access the pump housing and undo the pipes and electrical plug. From underneath undo the filler pipe and i think that there is a breather there as well, undo the mounting straps and lower the tank, check for any pipes hanging up and undo as required, lower tank out of cavity.
mark (mhpautos)
Nov 28, 2008 at 8:04 AM
