1988 Toyota Camry stop light switch
126,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHAELMAN5000
How can I test the switch to see if I need a new one.
The blinkers are working fine as well as the tail lights, but the brake lights stopped working all together.
Thank You,
Michael.
Oct 11, 2008 at 11:13 PM
  • 75,988 POSTS
Find the brake switch on the brake support bracket. Disconnect the brake switch pigtail. Check for power on the connector one of them terminal should have power if so-jumper it the brake light should com On-if so either the switch needs adjustment or replacement
Oct 12, 2008 at 2:33 AM
