1988 Toyota Camry stop light switch
1988 TOYOTA CAMRY
126,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHAELMAN5000
How can I test the switch to see if I need a new one.
The blinkers are working fine as well as the tail lights, but the brake lights stopped working all together.
Thank You,
Michael.
Oct 11, 2008 at 11:13 PM
Find the brake switch on the brake support bracket. Disconnect the brake switch pigtail. Check for power on the connector one of them terminal should have power if so-jumper it the brake light should com On-if so either the switch needs adjustment or replacement
Oct 12, 2008 at 2:33 AM
