1988 Toyota Camry oil leak and pcv valve location
218,743 MILES • 4 CYL • FWD • AUTOMATIC
WCEMERY74
I have a oil leak and I thought it was coming from the valve cover but I changed that gasket and still have the oil leak. I also would like to change the pcv valve to release pressure built up in the engine while running but don't know where it is located.Any help is appreciated. Thankyou.
Feb 23, 2009 at 6:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The 3S-FE engine series, while equipped with a PCV system, do not utilize a PCV valve (vehicle is not equipped with it).
Inspect lower intake gasket for your oil leak issue.
Thanks for using 2CarPros.com!
Feb 23, 2009 at 6:47 PM
