1988 Toyota Camry knocking
HED9870
Noises problem
1988 Toyota Camry 4 cyl All Wheel Drive Automatic
My oil sensor went out and all the oil ran out of it. There is a knock in the engine now. What is it?
Dec 22, 2009 at 10:02 AM
  • 31,937 POSTS
Hi there, engine knock after running out of oil is normally a failing bearing, if you continue to drive it you will destroy the engine, have it investigated first, but i feel that you will be up for a re build or a change over engine.
mark (mhpautos)
Dec 22, 2009 at 11:28 AM
