1988 Toyota Camry crankshaft spin
1988 TOYOTA CAMRY
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
RANDY PEARSALL
I am replacing the left side head gasket on my 2vz-fe 6 cylinder . I have the head off and the timing belt off and I went to turn the crankshaft around to see if it would and it wouldn't go all the way around, is this normal? it spins freely almost one revolution and I hit a hard spot. what could it be?
thanks for your help , Randy
Mar 1, 2010 at 7:48 AM
Did you remove all the sparkplugs if not do so and try spinning it-unable to the piston could be sticking/seized to the cylinder wall or a bend connecting rod-
Dunno the reason why you are replacing the head gasket-it must have overheated-could be hydrolocking-investigate
Mar 1, 2010 at 8:19 AM
