Engine Performance problem
1988 Toyota Camry 4 cyl Front Wheel Drive Automatic
how to change timing belt and locate timing marks
Friday, October 10th, 2008 AT 12:00 PM
MECHANIC
To get to the timing belt you have to remove the vibration damper/pulley, and both front upper/lower cover-raise the engine-if you haven't done such thing I suggest you bring it in
