1987 Toyota Camry Wheel bearings
ATTARD202
Tires and Wheels problem
1987 Toyota Camry 4 cyl Front Wheel Drive Manual
Hey there, got a problem trying to replace the front wheel bearings, ive taken the wheel of, taken the split pin out and the star shaped cover , and im trying to crack the main nut on the shaft... and for the life of me i cant crack it..? any ideas? ive done wheel bearings on old holdens, are these different? dan
Aug 18, 2008 at 7:14 PM
  • 31,937 POSTS
Hi there,
This nut is very tight and often need a 3/4" drive to undo it, the bearings are not the same as your old holden, this car has a double row ball race which is one assembly and is pressed in with special tools so they are not damaged, i think that this should be left to your mechanic to do.
mark (mhpautos)
Aug 18, 2008 at 9:29 PM
