1987 Toyota Camry Wheel bearings
ATTARD202
  • 1987 TOYOTA CAMRY
Tires and Wheels problem
1987 Toyota Camry 4 cyl Front Wheel Drive Manual
Hey there, got a problem trying to replace the front wheel bearings, ive taken the wheel of, taken the split pin out and the star shaped cover, and im trying to crack the main nut on the shaft. And for the life of me I cant crack it? Any ideas? Ive done wheel bearings on old holdens, are these different? Dan
Tuesday, August 19th, 2008 AT 2:14 AM
  • 31,937 POSTS
Hi there,
This nut is very tight and often need a 3/4" drive to undo it, the bearings are not the same as your old holden, this car has a double row ball race which is one assembly and is pressed in with special tools so they are not damaged, I think that this should be left to your mechanic to do.
Mark (mhpautos)
Tuesday, August 19th, 2008 AT 4:29 AM
