1987 Toyota Camry No power
400,000 MILES • 4 CYL • FWD • AUTOMATIC
LUVS2SKI
My camry has no power when I climb hills or really step on it. It shifts down to a lower gear but doesn't seem to accelerate. When I climb hills, the temp gauge creeps up to "H" and I end up slowing down and lose power to where I'm almost at a crawl. Radiator is good, fluids are normal...... where do I go from here? Is it spark plugs, plug wires, injectors??? I'm getting frustrated and confused.
Sep 7, 2010 at 2:50 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 7, 2010 at 5:52 PM
