1987 Toyota Camry Gear Stick
197,200 MILES • 4 CYL • FWD • MANUAL
GMZNDY
Gear stick is very stiff and does not change into gear. i changed the master cylinder and it still does not work. what could be the problem?
Jan 12, 2008 at 8:20 PM
  • 31,937 POSTS
Hi there,
You will have to identify whether it is a shifter problem or a gear box problem. If the clutch hydraulics are working and it is hard to select a gear, first have the gear box oil level checked. If OK, have the selector cables checked for smooth operation, this is something that your mechanic can do quickly.
Mark (mhpautos)
Jan 12, 2008 at 8:34 PM
