1987 Toyota Camry car stopped, makes grinding sound when i
25,000 MILES • 4 CYL • FWD • AUTOMATIC
OLDCAROWNER1
car just stopped yesterday as I was driving down the street now will not start and makes a grinding sound when i turn the key
Jan 28, 2009 at 8:13 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jan 28, 2009 at 8:19 AM
ZBUTT75
I have the same car and often the same problem. Its a problem with the flywheel, if you put the car in neutral and move it ahead slightly, it should always start.
Aug 26, 2009 at 3:15 PM
