1986 Toyota Camry Wont keep battery charged
199,876 MILES • 4 CYL • 2WD • AUTOMATIC
PERCYTHOMAS
First brand new alt was the first thing i did but that wasnt it. Problem started when someone tried to put a different radio in the car, the new radio never worked and i discovered an electrical nightmare of disconnected and exposed wiring hiding behind the face plate. The car will run for about 3 or 4 days then faithfully the brake light will start to come on whem i depress the foot brake or use the turn signal. The car will start to idle roughly and eventually will fade until it won't start unless i jumpstart it or recharge the battery on a separate charger. Any ideas what this could be?
Nov 4, 2010 at 9:33 AM
KHLOW2008
  • 41,812 POSTS
Hi percythomas,
The charging system is at fault and it could be due to :
1. Faulty alternator.
2. Connection between alternator and battery is open.
Did you test the charging rate, both at alternator and between battery posts?
Nov 5, 2010 at 4:04 AM
