1986 Toyota Camry Fuel pump location
JLORETO
Other Category problem
1986 Toyota Camry Engine Size unknown Two Wheel Drive Automatic 100000 miles
I would like to know where I can find the fuel pump on this model. I need to repair it and I dont know where it is.
Dec 15, 2007 at 4:32 AM
MERLIN2021
  • 17,250 POSTS
Remove the rear seat, and the cover plate under it. Test it this way...
https://images.2carpros.com/forum/automotive_pictures/62217_Pump_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Pump2_1.jpg
Key on engine off pressure should be 38-44 PSI, running 33-38PSI If you apply battery voltage as show, no more that 10 secs at a time! Pump can overheat!
Dec 15, 2007 at 4:48 AM
