1985 Toyota Camry Shifting
210,000 MILES • 4 CYL • FWD • MANUAL
SHAE74
Shifting cable broke and I have not been able to find another cable for the last 3 years. Is there another shifter and cable(s) I can use that will match up with slight modifications?
Jan 16, 2008 at 4:10 PM
  • 31,937 POSTS
Hi there,
You may have to check the part No with Toyota, They should be able to say if another model cable is the same, but i would say that you will not be able to modify a cable, you would be better of having one made. Have you tried on line wreckers? There would be some here in Australia.
Mark (mhpautos)
Jan 16, 2008 at 4:36 PM
