HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Symptoms
Hard to Start
SPONSORED LINKS
1985 Toyota Camry No Power
SKAASE
MEMBER
1985 TOYOTA CAMRY
Engine Performance problem
1985 Toyota Camry 4 cyl Two Wheel Drive Manual
250,000 hard to start, once started idle okay, can't give it gas or it will die, no power, back firing at intake
Thursday, February 12th, 2009 AT 8:54 AM
PALMSTER
MEMBER
1 POST
I have the same symptoms with my 85 Camry. Did you get this resolved? I've been wondering if it was something clogged in or around the Throttle Body.
SPONSORED LINKS
Tuesday, February 8th, 2011 AT 7:44 PM
FIXITMR
MECHANIC
Did you get it fixed? Sounds like fuel starvation/lean mixture problem. Did you get trouble codes read? Could be your TPS.
Saturday, March 5th, 2011 AT 11:02 AM
Please
login
or
register
to post a reply.
Related Engine Hard To Start Content
Takes Longer To Start Engine
My Car Started To Struggle To Get Cranked Up Even In Warm Morning Days After I Poured The Hole 12oz. Fuel Injection Cleaner Container In The...
Asked by
henry9
5 IMAGES
2007
TOYOTA CAMRY
GUIDE
Hard Starting
Popular Hard Starting Causes
Very Hard To Start
Several Months Ago My 1999 Camry Hard A Hard Start Problem When Cold (not Driven For Approximately 8 Hours). The Dealership Could Find No...
Asked by
raiderfan
1999
TOYOTA CAMRY
1993 Toyota Camry Car Is Hard To Start
Yes I Have A 93 Camry And I Just Changed The Motor In It The Motor That Was Install Is A 95 Camry Everything Hooked Up Right It Started Up...
Asked by
workmen 39
1993
TOYOTA CAMRY
Started Stalling Out And Became Extremely Hard To...
1991 Toyota Camry, Mileage: 139,000. My Car Started Stalling Out And Became extremely Hard To Start. I Took It To Our Excellent Service...
Asked by
2CP-Archives
1 ANSWER
1991
TOYOTA CAMRY
1994 Toyota Camry Hard To Start
When You Go To Start The Motor You Have To Pump The Gas Pedal For It To Start And Run. Runs Fine After It Is Started. Turn Off The Motor...
Asked by
john pro
1994
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
Fuel Pump Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
