1985 Toyota Camry Going Nowhere !!
TANOA
Transmission problem
1985 Toyota Camry 4 cyl Two Wheel Drive Automatic
My Toyota Camry starts fine but when i put the gear into Reverse or Drive it will not move at all. My Transmission fluid is at the required level. You do not even feel the movement that the gears have engaged. Can you help please >>>>
Jul 12, 2010 at 2:35 PM
  • 75,988 POSTS
You have a transmission problem-get it pressure tested to see whats really going on.
Jul 12, 2010 at 6:37 PM
