1983 Toyota Camry
186,520 MILES • 4 CYL • 2WD • MANUAL
SALTYDEUCE
car had drain on battery sat for a few weeks battery dead. Jumped battery car ran for a few minutes then died wouldn't start, got new battery installed it started car ran for few minutes died won't start, will grind and not start. Is it the fuel filter if so where is it at and if not what could it be it has ran like a top before the battery died.
Apr 29, 2009 at 11:36 AM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter and fuel pump and comeback with some results
Apr 29, 2009 at 1:23 PM
