cranks but wont start?
2010 TOYOTA AVENSIS
10,000 MILES • 4 CYL • 2WD • MANUAL
MAUNICK SOOBASH
engine not start check light not coming on the dashboard. diagnostic tools is not connecting to the engine ECM PCM?
Nov 9, 2010 at 2:16 AM
  • 55,432 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it:
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Jul 2, 2021 at 5:55 AM
