check engine light back on
CAMRY12
got error code p0330 replaced knock sensor an reset
check light a week latter light on agin same code any ideas 2000 toyota avalon
Oct 28, 2007 at 11:56 PM
2CARPRO JACK
  • 11,533 POSTS
v-6 ? If it has a small wiring jumper between the sensor and the main wiring harness, replace it. Was a problem on the older v-6's
Oct 29, 2007 at 4:08 AM
LOSTINMARS
  • 222 POSTS
[quote:344c42a673="2CarPro Jack"]v-6 ? If it has a small wiring jumper between the sensor and the main wiring harness, replace it. Was a problem on the older v-6's[/quote:344c42a673]
yep and its "still" a problem on them. its always best to change both while under there. toyota services the pigtail separate.
Oct 29, 2007 at 6:29 AM
2CARPRO JACK
  • 11,533 POSTS
Yeah, just wasnt sure if it was still a problem with them
Oct 29, 2007 at 7:50 AM
LOSTINMARS
  • 222 POSTS
yeah i think they might of finally fixed it with the 3.3
Oct 30, 2007 at 6:03 AM
